Spark Plug Change Advice
SilverRam11
4.7 V8
I have a very good mechanic but the shop he works at has a tendency to overprice easy jobs, case in point they wanted over $300 to change 8 spark plugs. So I have decided to attempt the job myself, I'm fairly confident turning a wrench so what the hell. I ordered 8 OE plugs and this nifty looking tool.
https://www.amazon.com/gp/product/B01MZ25YJU/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Any advice for this job? Any major do's or don'ts? Thanks in advance.
daveray9
The rams have 16 plugs :)
Sent from my SM-G920V using Tapatalk
Burla
2010 Hemi Reg Cab 4x4
That socket should help, might want an extension as well.
Before you put the plugs back, take note of the plugs condition as you take them out. I would take 8 paper cups and label them and drop the pulled plug in the tight cup, so you can easily identify any problem cylinders.
I like using anti sieze when putting back plugs, that makes it easier next change. Dielectic grease can be helpful protecting the cap, or more persise where the cap meets the top of the sparkplug. Keeps stray current down and keep water out. But, you don't want it on top of the plug, you put it on the side of the plug or rubber, but try not to get it on the small silver/copper top.
If you see a real bad plug, good time to clean that cylinder.
S
SilverRam11
4.7 V8
Yes but I don't have a hemi so I do not have 16 top side spark plugs. I have 8 top/intake plugs and 8 bottom/exhaust plugs (at least that's how I have come to understand it). I'm pretty sure I read that the bottom exhaust side plugs were 100k change interval so I'm only changing the top 8 copper plugs. Please correct me if any of this is wrong.
edit: checked rock auto and the intake side plugs are (8) copper and the exhaust side plugs are (8) irridium
S
SilverRam11
4.7 V8
I like using anti sieze when putting back plugs, that makes it easier next change. Dielectic grease can be helpful protecting the cap, ot more pressie where the cap meets the top of the sparkplug. Keeps stray current down and keep water out. But, you don't want it on top of the plug, you put it on the side of the plug or rubber, but try not to get it on the small silver top.
Thanks for the tips. The plugs I ordered have threads already coated for anti seize and I have dielectric grease I can use.
Burla
Let us know the condition of the plugs, so few of us post up results. Maybe pull a couple of the exhaust plugs if you see corroded top plugs, just to check the condition, since you are already there doing stuff.
daveray9
Woops, totally missed your engine type sorry man.
That socket might not fit,i had to grind down a plug socket to do the plugs on my old 13 that had a 4.7.The 4.7's are very tight around the plugs.it might be okay,just fore warning you,you might need to grind it down a bit.
S
SilverRam11
4.7 V8
Yea I'm a little worried about it but if the one I ordered doesn't work I will try to order a thin walled socket and figure out how to make it work.
quietpeen
2021 TRX
Hellcat
I thought in 08 or 09 they changed the 4.7L to 16 plugs?
quietpeen
2021 TRX
Hellcat
found this on allpar.com
The 2008 redesign had two spark plugs per cylinder, a 9.8:1 compression ratio, better port flow, and new slant/squish heads.
You should maybe read the 4th post again,he already knows he has 16 plugs,but he's only changing the top side plugs,as they're copper
quietpeen
2021 TRX
Hellcat
I can't read it again since I never read it in the first place :insane:
huntergreen
Marine Corps Navy Badge
Burla, how does one clean a cylinder? Thanks
huntergreen
Wonder why they used two different plugs?
S
SilverRam11
4.7 V8
My guess, and it's just a guess, is the nature of the plugs and their location. If they are in the exhaust side and harder to get to, then using iridium and only changing every 100k makes sense.
S
SilverRam11
4.7 V8
Update: I cleaned my engine compartment all nice and shiny and realized it was way harder to get to the damn spark plugs then I imagined. I didn't want to screw something up so I think I'll let a professional do it. Hopefully this doesn't cost me my man card lol.
