Speedometer reading wayyyy off
Travisstorbakken
South dakota
So I tore apart my dash the other day to try to replace one of the lights on my gauges. I unplugged the cluster and it all goes limp of course. I plug it back in and the speedometer pointed directly down and the fuel gauge went past E in the wrong direction. They both still work but obviously not showing correct. How do I fix this?
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
Was The Ignition switch in On/run position when you unplug it
was the battery disconnected when you began the job ?
nevermind,
disconnect the Negative Post from the battery & reconnect it after a couple hours, hopefully something will reset itself
T
Travisstorbakken
South dakota
Nope to both inquiries above… didn’t think anything of it honestly. I just figured the speed sensors would reset it
jawzs2
Air Force
South Jersey
If I remember correctly, you can try to do a reset on the cluster. Press and hold the odometer reset button and turn the key on, in a few seconds it will start to go thru a self-test. Release the button and let it do its thing.
T
Travisstorbakken
South dakota
So I tried the reset. It did the whole scan thing and thought it almost worked but sadly fuel gave and speedometer is off just the same
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
If it is not the connector seated correctly, a bent connector pin or two, or off by a pin, if that is even possible, then somehow the DIC was damaged.
T
Travisstorbakken
South dakota
So I read that those cluster codes are like out of date or indeterminate of lrettt much anything those trucks..
