Splash guards / mud flaps yah or nah??
Auk1016
Cleveland, OH
First real experience with crap weather here in NE Ohio since I got my Big Horn and running boards on. They get loaded with crap from the roads. So the question is guards / flaps or leave it the way it is without??
If get them, any suggestions??
Administrator
mudflaps are somewhat of a personal preference for they're looks. If you travel down dirt road regularly they will help keeping rocks/dirt from scratching up behind the wheel wells. As far them keeping the running boards clean, probably not. I have HuskyLiner moulded mudflaps on my 15 and still get slush build up on the running boards
Papa Red
Papa Red
Nebo, NC.
I'm going to get mud flaps once my truck is delivered in a couple of weeks. I've heard the weather tech flaps are good and easy to install. That's the direction I'm going to go I think but I will follow this thread in case there's something better.
Red
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
I went with the OEM Ram molded ones that fit the contours of the truck. Pretty inexpensive, and super easy to install. Keeps a lot of the crap from flinging on the truck. Biggest thing for me is the tires always pick up rocks and fling them, these help keep those rocks from bouncing off rockers.
JD Martin
Southeast
Definitely get them. Before I got them my truck always had spray crap all over the sides. It was a matter of time before the truck was going to be scratched up. I got the Husky ones and they are great. Put the clear film on before you put the mudguard on.
Tumbleweed
Hmmm...
I visited Weathertech's site to verify fitment. They only showed the rears for my 2018 2500. No factory flares, less than 2" between running boards and wheel well and Not a dually. P/N: 120024
Went to Amazon and found both front and rear but different P/Ns: 110026-120026. So I sent an email to Weathertech. Probably won't hear back until Tuesday or so.
Tick Tock
avantiguy
Bay City, Mi
hemi
A word of caution on the Mopar ones, they fill up with water, crap, gravel etc and will freeze solid. The drains in the bottom will not allow for drainage. I pitched mine, even though they are the best looking ones, and replaced them with Husky's.
The advice on protective film is dead on, The Mopar ones don't come with any and after less than two months mine were starting to wear into the clearcoat.
fast ed
hemi
why use protective film. are you putting them on, off, on,,off
Puba08
Long Island
Definitely nah
tourrider
Grumpy
NW PA
CTD 6.7
I'm in NW Pa. They really help reduce the snow/ice/slush build up on your running boards, and up the side of your truck.
I went with a set of Weathertech NoDrill, good fit.
Sent from my SM-G975U using Tapatalk
avantiguy
Bay City, Mi
hemi
All the name brand ones come with the film so I would think that's one data point. Secondly, I pulled the Mopar ones off, they didn't have the film included when I bought them, my 19 Laramie after 2 months and there were visible lines where the top of the flap met the fender flare. I polished those out.
There was also an area of more wear near the bottom of the flare that required a touchup of clearcoat and then a polish to make it look new.
Apparently the flaps have movement even when bolted in place so your truck - your choice. Mine is to use the film.
BTW I'd highly recommend them on any Ram is snow country or gravel roads. The first trip in my 14 Sport with running boards resulted in slush thrown all the way up to near the windows. Flaps reduced that substantially.
Pino F
New York
3.0L V6 Turbo Eco Diesel
I installed Husky mudflats on mine, I definitely recommend them. I think husky are a little longer than weathertech.
Pino
Tracy in IL
Moline IL
3.0 diesel
Careful on Amazon purchased mudflaps. I did and they were cheap China crap that didn't fit. WeatherTech all the way, easy-peasy to install, look great. I also did WT front bug/rock guard and floor mats. Greatly pleased at ease of installation and looks. Mudflaps definitely decrease amount of splash up on rockers.
Marshall
Sk, Canada
2014 sport
In this area, I have never seen a truck without mud flaps.
DA Smith
Marshall Texas
I put the Mopar factory fit mud guards on mine. You are correct about collecting water and crap in the open top design. I liked the fit and factory look so instead of getting rid of them I did a easy fix on them. I stuffed News paper in the holes leaving it about one inch from the top of the holes and then topped it off with black silicon rubber sealant. Just filled it using a caulking gun and a wooden pop sickle stick to smooth it out nice and flat along the top. Easy fix now they are sealed up and the black caulking looks like it came that way.
txvet33
hemi
Ebay $40 for both front and back. My paint is still like new. No, the running boards will not stay clean with mudflaps. 16RAM2.jpeg
