R/T_Fire
- Joined
- Feb 3, 2015
- Posts
- 3,432
- Reaction score
- 1,207
- Location
- Pleasant Grove
- Ram Year
- 2011
- Engine
- Hemi 5.7
So im finally getting to double checking the perfect adjustment on the rear and now that im really spending the time to triple check everything numbers arent adding up.
So i have my pinion angle set no prob, but having an issue getting all axle location dimensions to add up. Lower arm adjuster nuts same length, lower control arm front bolt to shock bolt same length but things get wonky around the wheel well distance im 1/2" off on dimensions in the fender well and hight in the fender well. All frame dimensioms seem to equal out but not to the body.... at a loss of where to find the issue
Sent from my SM-G920V using Tapatalk
