spring question
ram15
Mendocino, Ca
would it be possible to put some 3/4 ton coil spring on a 1/2 ton to lift it or are they too wide. if they're not to wide i could cut a few links off cause i know they're too tall. just wondering cause it would be cheaper im just not sure if they would fit.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I have heard of people doing that as a cheap leveling kit. Will make the front stiffer too.
Sent from my apple torching Droid.
R
ram15
Mendocino, Ca
yah i don't mind it too be a little stiff. also i like the idea of less moving parts, one spring rather than a spacer stuffed in there.
