spyder headlight + kensun hids
Lone_Wolf
Illinois
2016 Ram 2500
hemi 6.4
just got a set of kensun hids with their antiflicker things, and im completely confused,can any of you guys help me out on how to hook all this up please?
InspectGWS
Houston, TX
2014 JEEP GC SRT8
6.4L HEMI
Did your RAM come stock with projectors?
I do not think Spyder makes an aftermarket RAM headlamp assembly that replaces the stock projectors, they replace the stock quads...
L
Lone_Wolf
Illinois
2016 Ram 2500
hemi 6.4
no its an 11 it came with quads. i was told i can upgrade the h1 in the projectors on the spyders with hids
RAMthevbied
I'm running the same setup with no problems. The h1 hids will replace the h1 style halogen bulb that come with the spider projectors. Do you have a relay harness wired up? If not, you will need a relay harness to properly power the ballast for the hids. If you try to wire the hids directly from the battery, you will fry your ballast and possibly damage the trucks electrical system. The harness is pretty self explanatory, with power from the battery, a few ground connections and hook ups directly to your lights via the hid ballast. Try a youtube search for a video for this, I will try to post a link to another forum write up I used to help me with my install. Hope this helps
Sent from my KFSOWI using Tapatalk
L
Lone_Wolf
Illinois
2016 Ram 2500
hemi 6.4
i got it thank you, but now im having problem with the halo causing me to blow a fuse?!
