Sqealing sound...
Daddyhas2boys
So I have a 2009 dodge ram the issue I'm having is when I'm turning left it makes a sqealing sound similar to brakes sqealing but all the brakes are newer and it seems to be coming from the front end??? The hub bearings are less than 3 years old as well the the tie rod ends....any thoughts???
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Sounds like, it could be steering related. I like to start with easy first. Serpentine belt. Power steering fluid, pump. Rack. Getting it up on a lift that allows you to replicate the steering noise should get you to the problem quickly. Stay tuned. Others may have a quick common fix.
D
Daddyhas2boys
Serpentine belt and idler pulley are within 3 months old...mopar products of course
Tapperoo
Raymore, MO.
Cummins Diesel 3500
Did you ever find the problem.? I have a 2022 3500 Cummins. It’s making a high pitched squeal/whine when turning left. 40K miles.
