squeak from trans
biker50610
nc
2001 ram 4x4
I have a 95 2500 heavy duty, it has the 5.9 gas in it, auto, an 4x4. There is a squeak sound when I put it into drive or reverse. It will go away some times at speed then when I let off of the gas it comes back. Checked the fluid in it and it is not low. Is there any idea of what it could be? I don't do trans so have an don't know rams every well. Hoping I don't have to replace the trans in it. Want to get it fixed or stoped.
Merc225hp
NA
truck
gas
Have you checked the u-joints yet?
B
biker50610
nc
2001 ram 4x4
Don't have to its not them. Turn the truck on, press on brake, shift into drive, keep the pedal mashed an it makes the sound. If I shift it into nut then it stops the sound.
NYCruiser
Yonkers, NY
Do you hear it at all if you just rev it up in neutral?
NYCruiser
Yonkers, NY
I would get it serviced by a tranny shop and see what they say. Could be a band slipping or a torque converter issue. Better safe than sorry.
