Sramcq09 install help!
Schultzie
Ontario
Hey guys I joined this forum for some help. I have a 2014 ram sport. Alpine audio system. I used to deal with car audio and I read all these threads saying it was an easy install. My question is whether the ram sport has the premium audio or the base? I've tapped the wires to both harnesses to try and get the sub to work. It doesn't. Green light is on the amp. I'm frustrated standing out in the rain trying to figure this out. Has anyone installed this kicker upgrade on the sport? If so what wires do I tap?
Thanks in advance.
Eestee70
Chicago
Does your system have the factory sub. If you have the kicker upgrade then it should have been plug & play
S
Schultzie
Ontario
I do have the factory sub. It's not just plug and play there are some small wiring work required. I followed everything as per instructions but the sub won't work. New amp light turns on.
S
Schultzie
Ontario
The factory sub is the 8" round. The vss system comes with a new amp and sub
12sportmc
NC
Did you disconnect the factory sub? It has to be unhooked for the kicker stuff to work. Also check if you flipped the wires around on the 2 speaker splices under the dash
S
Schultzie
Ontario
I took the old one out. Which wires are supposed to be tapped?
12sportmc
NC
Gray with brown stripe and green with brown stripe. 180facd0d9e0f767fcfefc575b07b558.jpg
S
Schultzie
Ontario
I bought a display model so I don't have those instructions. Thank you so much.
12sportmc
NC
If you need more help on the kicker website you can download the instructions book. Good luck. Hope your not as disappointed as I was with the bass
S
Schultzie
Ontario
Ya I looked at the kicker site but I couldn't find any answers on the alpine unit. Well I just hope it's better then the stock alpine unit. Did you notice 2 green/brown and grey/brown in that harness?
12sportmc
NC
Yes They are for the fronts. Just tap a matching pair. They should be right next to each other
12sportmc
NC
http://www.kicker.com/SRAMCQ09
Scroll down to manuals and download instructions [emoji106]
