stalling
kalebm
fort worth
i have a 2006 1500 with the 5.7l hemi and about a month ago i was heading to work and my truck lost power and shut off going down the highway. It would start back up but would struggle doing so. what would cause this problem?
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Lots of possibilities. How many miles are on the motor? When did you last fill up with fuel before it happened? Have you given it a tune up at any point? Has it continued to happen? Was it raining? Were there any UFO's in the area? Need a little more information.
Later2u
West Coast
Have you had the transmission serviced recently, fluid change?
First time i did mine, at a shop, everything went well except a month later is started to stall in the morning. It would start and keep going after that. Check the trans fluid and it was a quart and a half low. Topped it up and it went away.
