Starting issue?
2NDGENGASSER
360 Magnum
99 halfton with a 360 sometimes doesnt start, usually after i get fuel lol fill up and go to leave and the truck wont crank.
Tested the battery, its rated for 710 cca and tests out at a bit over 600cca. Just replaced the starter, and my alt. Is putting out about 14.6. Also just replaced the cable ends... What am i missing? Lol shift linkgage? (not right from when i reinstalled a trans??) ground issue?
Thanks for any advice
Merc225hp
NA
truck
gas
When it gets pissy have you tried starting it in "N"?
2NDGENGASSER
360 Magnum
when it gets pissy have you tried starting it in "n"?
thought about that last night after i got it started again. First time it did it my buddy pulled me to his gpas house so i could put it on the lift(thats when i changed the starter) and it started in neutral, then last night i had some one pull me out of the way of the gas pump and i put it in park to unhook my strap, fired right up once i got back in there and tried the key again. Which makes me lean towards shift linkage....
Merc225hp
NA
truck
gas
I think you are right shift linkage need adjusting if possible.
No members online now.
geneseedennis
