- Joined
- Feb 9, 2025
- Posts
- 724
- Reaction score
- 1,402
- Location
- Louisiana
- Ram Year
- 2026 Limited
- Engine
- 3.0L TT H.O.
Engine is basically stock for now, other than the 6.4 intake swap. Wanted to try and get this little "issue" ironed out before the headers go on and I get my tune. Since installing the intake, I've developed a slight hesitation on startup after the truck sits for a day or two. I don't daily drive this truck and it often sits for a week or longer without any starts.
I also installed a catch can which I've disconnected (went back to PCV valve) to eliminate that as a problem.
Battery is newish, load tests fine, and I keep it hooked up to a NOCO Genius2D.
I don't have any apparent manifold leaks, and I rechecked all the bolts. When I did the swap, I tested/cleaned the factory injectors and they all looked good. I thought about hooking up a fuel pressure gauge, but see that these trucks don't have any sort of a schrader valve.
I do have a VERY HARD brake pedal when the hesitation occurs. Goes back to normal after startup. If that offers any clue(s).
I do have a CEL for the dumba$$ P0456 (very small evap leak), but I ASSUME that wouldn't have anything to do with this. I plan on either getting it smoke tested, or just tune it out with my HPTuner.
Any ideas for a starting point on what to look for?
Here's the link to the YOUTUBE short to hear what I'm talking about.
