Steering Angle Sensor code U0126
Burn2k12Ram
Reno, Nevada
Other night had two codes popup and the traction control light came on and stays on. Code U110A(Lost communication with the SCM-CAN-C) and Code U0126 (Lost communication with Steering Angle sensor). Tried to manually reset Steering angle sensor by turning wheel hard left and then right three times but to no avail.
figure either bad SAS(Steering Angle Sensor) or bad connector. How hard is it to get to in order to swap or check connectors? Or what are your thoughts is there anything else I can try? Thanks
