Steering Click
rodsnguns
Ga
Hello, 2007 ram mega cab here. I occasionally have the "click" in the steering column. It's not the clock spring, turn signal switch, or anything at or near the rack/pinion or rubber boots, etc. Under there. That theory is squashed. It is clearly inside the cab behind the steering wheel. Sometimes very faint and sometimes very noticeable. It can sometimes be felt thru the wheel and around the covers in the ignition and turn signal areas. Sounds just like when applying turn signal lever or when it cancels. Quite the mystery. If anyone has had this same issue and got it resolved, I would be interested to know what the mystery is.
Thanks ahead.
ftytoor
