Steering Column Gear shift Boot
norman72
Louisville, KY
Why can I not find just the boot? The boot around my steering column gear shift lever is broken. I cannot find just the boot. Everywhere I look I have to buy the lever also. Can anyone help me find just the boot? Picture attached 2009 RAM 1500 BigHorn 4x4...
2009 - 2012 Dodge Ram 1500 cabs & transmissions
2010 - 2013 Dodge Ram Heavy duty models
were basically the same, when the transmission shifter was on the steering column
Where can I find the rubber cover? I am not having any luck...
A buddy of mine tried to find the boot seperately a few years ago with no luck either.Makes me think it might not be a seperate servicable part,so you might have to live with it,or buy the shifter assembly.He just lived with it,and said he quit looking at it,that way it didn't bother him as much,lol
This seems to be the part
I would ask in the 'Click to Talk', to verify
  • Genuine:
  • SKU:68400287AA
  • Other Names:Boot
  • Description:
    Only for Ram 1500 models, 2500 and above require the shifter assembly to be replaced.
    Serviced With Lever If Shaded Out.
  • Condition:New
  • Applications:Chassis 60" CA Regular Cab 4x4. Chassis 60" CA Regular Cab 4x2. Chassis 84" CA Regular Cab 4x2. Chassis 84" CA Regular Cab 4x4. 60" CA Chassis Crew Cab 4x2. 60" CA Chassis Crew Cab 4x4.
They are very vague :
they ask you to refer to # 19 to view the part
There is no #19, that i can see
Blademan
Earth
2016 2500 and 2018 3500
6.7L Cummins
I know it’s been a while, but did you ever replace the boot? And if so, what was the procedure?
Daw14
South Florida
I bought just the boot a few years ago , part # 68400287AA
I purchased from eBay
Nismopar
April of 23
Approximately $30 plus
It is still on the shelf , have not installed yet.
JambaJoe
Georgia
I found this thread a couple of weeks ago while trying to find the replacement boot for my 2014 1500. For whatever reason 2014 only shows up by ordering the whole shifter. The boot (68400287AA) for everything else looked the same and I found one on Amazon for 16 bucks. This part does in fact fit a 2014 1500. The only thing I messed up was I stretched it over the knob instead of taking the shifter apart. It split the collar a little. For 16 bucks I will probably order another one and install it the right way lol.
Daw14
South Florida
It does not look to terrible of a job , but I put it off ,then forgot about it .
Now that this post showed up , I suppose it is time to get er done.
I will try to post any tips if possible ,when I’m finished.
