Steering stabiliser question
Dinky
Oregon
Thuren king damper. Direct oem replacement
SeppW
Northern VA
Hemi 6.4L
The OE damper is pretty good. Ditto above on the King. Could go hydra-assist as well, requires replacing the steering gearbox, unless you want to mod it to accept the hoses, and replace the damper with hydraulic cylinder. Dethloff MFG used to carry the kits but hasn't in some time. I assume COVID-related supply chain issues. PSC carries the kits as well. Probably a small fortune to get one into country.
crazy jerry
WY
factory one works well. but why do you care if you dont have a pw ?
Dinky
Oregon
The OEM one has a little bit of movement before it actually does anything. When i switched min out i expected some resistance on the bolts but i unbolted it and it fell out. after i replace mine with the king damper its night and day different. pot holes or bumps off road no little jerk or deflection you will know how good the oem one actually is.
mtnrider
Georgia
I'm still running the original OEM on mine, 35's with ~115k on the truck and it still works great.
Be careful with the "charged" style stabilizers, they can add pull if you truck is running straight now.
4xdad
Edmonton Alberta
2015 powerwagon
I run a bilstien on a synergy steering correction drag link the bilstien bracket didn’t fit because the drag link is bigger in diameter so I used the stock one with bigger u bolts
4xdad
Edmonton Alberta
2015 powerwagon
Anybody need a mount that will fit a stock pw
4xdad
Edmonton Alberta
2015 powerwagon
I had to grind the the sleeve in the new stabilizer about a sixteenth of an inch I hate modifying new parts lol
Power Wagon NZ
Auckland, New Zealand
Thanks for your explain. If OE one is fine with 37 tyres i will just keep it as stock.
olyelr
Kewadin MI
Yea, i would just run it with the factory one for a while and see. Then if you feel the need to upgrade you can do so later.
crazy jerry
WY
you got a mess going on sir. all in the name of bullet proof ? :anitoof:
4xdad
Edmonton Alberta
2015 powerwagon
I replaced the steering gear because I didn’t like the oem recall solution of welding the jam nut to the adjuster nut plus the link is stronger the ends are serviceable and bigger tires puts more stress on the components nothing wrong with strength and protection unserviceable ball joints are no good in my opinion I know how to run and load a grease gun and I not afraid to crawl under my truck and use it
olyelr
Kewadin MI
You mean drag link, not steering gear.
4xdad
Edmonton Alberta
2015 powerwagon
The synergy steering stuff was pricey but well worth the money the bilstien steering damper wasn’t that bad minor wrenching issues is half the fun
