Steering wheel and memory seats questions
Kinetic
I just bought a 2015 1500 Sport fully loaded. I have two questions about things I want in it:
1.) Does the Laramie Limited model steering wheel fit the Sport? The Limited model has the wood grain on the top with leather the rest of the way around.
2.) Is there any way I can add the 'easy exit' feature?
If anyone can confirm either/both questions that would be great. TIA!
edit: Sorry wrong section, Mods please move to interior section
Diller
Nashville TN
6.7 HO Cummins
If it is "fully loaded", then you should have the 8.4 screen. If you go to the options menu, you should be able to find the option for the easy exit. Also assuming you are referring to the seat moving back when you turn off the truck.
Kinetic
Kinetic
It's fully loaded for a Sport, but i was told only the Laramie has the easy exit feature, is this correct? I'll look again for through the settings but I'm sure i didn't see that option. If it is true, I wonder how I could add this feature and has anyone else done it?
