Steering wobble
2names
EDM
2014 2500 I've been having a slight wobble felt in the steering wheel when I make slower turns either left or right. I believed the tires may have been wearing funny so did a rotation on them. It improved slightly, but when I towed my travel trailer you could definitely feel it was still there. Any ideas where to look for the issue?
Gettinshifty
Colorado
5.9 Cummins
Never had wobble on my ram so can’t give specific advice, other than check the usual culprits: ball joints and steering linkages. Aftermarket stabilizer could help. The only advice I can give from fixing it on my jeep is bite the bullet and replace all worn items at once. If you try to replace them piecemeal you’ll just wear out the new parts twice as fast.
gtomike60
Milford,Mass
5.7L HEMI
Check the front axle shaft u-joints
When the bearings in the cups dry up,they start to bind,causing the issue you're having.
joshhhh
