Stereo Upgrade?
Kapt
3L
I wasn't going to upgrade the 8.4 Alpine system in my 2016 Laramie Ecodiesel anymore than I already have, but I'm thinking I just might do it after all. Right now I have changed all three dash speakers to Infinity 3 1/2's, and added two Kenwood 12's under the back seat powered by a Kicker 600.1 amp.
I'm thinking of removing the LC2i and replacing it with this. Then adding a Kicker four channel amp. Since I already have Infinities in the dash, I was thinking of adding Infinity 6x9's to all four doors. Then tapping the left and right dash speakers to the 6x9's in the front doors, leaving the center powered by Alpine and just there. The rear doors would be run alone on the rear of the four channel. Subs would continue to run as they are now.
Thoughts?
adurm
FL
2015 RCSB
I say do it. I'm not sure how that pac provides flat eq unless it's already flat from the head unit. You could just run the lc2i main out to the 4 channel amp. You would lose fade but you could always turn the gain down a smidge for the rears of needed. Some amps can do 4 channel out with only 2 in or you could use a y adapter for the rca.
I wouldn't tap the door and dash together. Too big size and power difference. Not to mention the ohms.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Eestee70
Chicago
I completely agree with you SOCAL....but remember we're looking at a shop doing a customers truck. It may not have been in the customers budget to do more stuff. With your full dynamat build I'm sure you probably passed out from the band-aid they used for deadening the door. LOL.
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
:word:
adrianp89
Tampa Bay, FL
Can't see the video - but how much power is going to the doors? I wouldn't even bother upgrading until we are talking 200-250RMS per door.
Witch
Hemi 5.7 liter
75ish to each door.
I am digging the plug and play approach and the app tuning rocks IMO
I agree with Eestee though, being it was a customer and not a personal project they simply installed what the customer wanted,
it is an expensive system so it could have been a budget constraints
Eestee70
Chicago
There are a lot of thing that aren't in our budgets......but with financing it opens up the possibility of getting what you want and not spending a large chunk of money at one time. thats how I purchase my stereo equipment. Some places even offer 90 days same as cash.
Kapt
Kapt
3L
Well, my original plan is going to cost right around $700 for what I want to do. This new plan would cost a little over $1,200. I could do it, and I know it would be way nicer when finished, but I do have to sleep at night with my wife, and I go to sleep earlier than she does lol
Seriously though, I'm looking and trying to find a less expensive compatible amp and we'll see what happens. If I can shave a couple hundred off the price I can sell her on it
Eased
Canada, eh?
2014 1500 Sport
5.7L V8 HEMI
This is awesome. Exactly what im looking for. It's a shame that this is the route you have to take to integrate into the factory systems these days.
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Even if you don't buy there, crutchfield.com does a nice job of showing you what's compatible with factory setup. I went there, but ended up yanking everything out as I had the old RA2 unit. I sold it on Craigslist for 100 buck though, so it wasn't all bad. :naughty:
Witch
Hemi 5.7 liter
The other side would be the PAC audio route
It is a good one but still need the 250 dollar adapter and harness for your RCA out with a 5 channel amp
Unless you are staying with the factory amp
Kapt
Kapt
3L
That's actually the rout I'm going. It'll end up being three amps in the long run (already have one), but I got everything including tape and wire loom for less than the cost of the amp in the video.
Eestee70
Chicago
Kapt, can you explain why you would do three amps.
Kapt
Kapt
3L
Front, rear, sub. Front is four channel for 6x9's in the door, and the 3.5"s in the dash. Rear and sub are self explanatory
Eestee70
Chicago
normally you wouldn't use that many amps unless you're running an active system...I'm asking so many questions because if we can point you in the right direction it will save time & money
