stereo upgrade
Troutman
3.6 pentastar
I have a 2019 1500 Bighorn with Uconnect 3. Can I upgrade to Uconnect 4?
Ricks Ram
Yes you can. It's very easy to do. You can find info in the 4th gen DIY section. There is NO special programming required as some online vendors state. It will work plug and play. If you get the radio out of another Ram truck you will need to get the four digit unlock code which is easily done. In order for the Travelink/Realtime Traffic to work you will need to enable the code in the BCM which is also easy to do and explained in the first post of the alfa OBD thread.
