"stiff" steering?
jljbtm
I drove my 2011 to work this morning and everything was fine this evening on the way home the steering was very stiff and jerky. I have about a hundred and forty thousand miles on a 2011 anyone else have a problem like this?
Sent from my SM-N950U using Tapatalk
Brandon-w
Yukon
2015 Ram 1500
Sterring shaft u joints most likely.
jljbtm
jljbtm
Just like that? Is it common on these trucks
Brandon-w
Yukon
2015 Ram 1500
Mine did it sitting in a restaurant. Fine when I went in when I came out it was stiff didn't wana return to straight and it was kinda scary to drive. I took my shaft out lubed it up. Been good for a year now. Next time it does it I'm gonna drill a hole in the u joint end caps and put grease zerks in it.
smoothee
St. John's, NL
Yeah I second the steering shaft u-joint. Grease worked for a while, but just had to replace it because it was shot.
meedom
Definately check pump and fluid level....
