Strange Hyper Flash
Algernon
Fairbanks, AK
Need help, please read carefully. I have a 2013 Ram 1500 Express Quad Cab. I replaced my rear turn/tail lights with led bulbs. I did not use resistors at first. The LED turn signals flashed at the normal rate but the factory LED mirror turn signals and green dash arrow did hyper flash. I also got the "rear turn signals out" message. When I put on the hazard lights everything flashes just normal. I tested my 3 wires to my rear tail/turn signals. Black-ground and white/green stripe-turn signal. I put the resistors on the ground and signal wire. This did not change anything, the rear turn signals still flashing at normal rate and factory mirror LED still hyper flash along with the dash arrow and the warning message. Should i put the resistors on the factory mirror LEDs?
