JordiUK
Here we go again.
2003 4.7 with 194,000 on it. P0315 and p0339 crank faults.
Starts, idles lumpy (revs climb and drop, sometimes cuts out). Fine when warm.
Drives fine, pulls well till 3500rpm then misfires like hitting a limiter.
Various diagnostics ran. Fuel pressure is good.
Plugs, coils, cam and crank sensor replaced. Crank wiring voltage abd resistance checked. Still the same.
New code, sometimes P0016 (cam & crank).
I’m now leaning towards a stretched chain or even jumped a tooth?
Is there an easy way to check my timing that doesn’t involve stripping too much off the engine?
Do these symptoms sound similar to anyone elses experience of a stretched chain?
Thanks.
Thanks.
