Stubby antenna
Matt Todd
Laurel DE
I’m looking to get a stubby antenna...I was wondering if the base comes with them or not or is there even a market for the bases? I ask because my stock black one is faded and looks like crap.
Side question...if I can’t buy a new base, can the current one be taken off and just painted?
Pana
Hawaii
Aloha, I have the Ronin 50 cal. It did not come with the base and the previous stubbys I've owned did not either.
You could also use the Forever Black Bumper & Trim to restore the base (you can buy on amazon). Its more of a dye than a sealant so it's just like "re painting" it but made specifically to adhere to trims and bumpers (as the name suggests).
Hope this helps.
Matt Todd
Matt Todd
Laurel DE
Hope this helps.
Do you just apply it while it’s still on the truck or do I have to take the base off?
JB1
Houston, Texas
Gordinho80
Monroe, NJ
2012 1500 Big Horn
I took my stock antenna off, removed the ball on the end, cut it to my desired length, filed down the end, replaced ball on top and painted it black...freebie
Pics?
MidwestJ
Illinois
JB1-what’s your reception like with that mod??
How’d you cut it and what other steps you take?
Truck looks tough.
Reactions: JB1
JB1
Houston, Texas
Reception is great, I haven't noticed any change.
To get the ball end off, use some pliers and kinda work it back and forth while using a twisting motion, it's a press fit. Then I just determined the length I wanted, placed it in a vise and cut it with a common hacksaw. Next I sanded it down with sandpaper. Next I used a file to remove any burrs where i cut it and kinda file it to a taper, during the filing I would test to see if the ball would go on the end. Keep filing until you can twist it on with force. Then I just spray painted it semi flat black. I like it because it looks unmodified and performs as oem
PoMansRam
East Aurora NY
I bought a cheap shorty whip antenna off eBay for my Ram. Reception was so bad with it I'm back to the OEM antenna.
spdglez78
US
I had the base painted and went with an amazon stubby which causes the reception to suck. Use pandora most of the time so doesn't really matter.20180512_113640.jpeg20180512_113542.jpeg
PoMansRam
East Aurora NY
^ Looks great!
I think the rubber whip stubby I bought off eBay is made of bubble gum and industrial waste. Literally got NO reception with the thing.
Matt Todd
Matt Todd
Laurel DE
So what I’m hearing here is the brands seem to matter with getting decent reception?
Ohio5pt7
Ohio
My VMS works perfectly.
Sent from my SAMSUNG-SM-G891A using Tapatalk
mjb765
Long Island
I'm going to order the short VMS antenna....for $14 I will give it a try
Ohio5pt7
Ohio
It's worth the 14 trust me
wobly
Colorado Springs, CO
2021 Ram 2500 Power Wagon
I ordered this one from Amazon over a year ago... https://www.amazon.com/gp/product/B01M6CAZKK/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
It has worked well, not as good as OEM, but pretty close. I chose it versus cutting the OEM antenna since when I am hunting or driving through trees and bushes, this doesn't get pushed/pulled like a regular antenna would. My son did the "cut the OEM antenna" mod and it looks good. But, I like my antenna better. :)
Pana
Hawaii
@Matt Todd I would jsut tape off the edges surrounding the base of the antenna and apply it. I've never tried taking off the actual base of the antenna.
Reticle918
