Stuck in 4th intermittently
Jim's Express
Northern Ontario
Hemi 5.7 6 Speed
Love my 15 Express. It has a 5.7 and a 6 speed with column shift.
Every once in a while when I start it up and shift into reverse to back out of the driveway then put it in drive I notice that I am 4th gear. I can't change it with the +/- and it will not upshift or downshift on it's own. Sometimes the check engine light is on as well.
If I shut the truck off and restart, all is well, it's in drive again. If the check engine light happened to come on, it takes a couple of restarts, or a period of time I guess, then that goes away. So nothing major.
It's only happened about 4 times. I'm thinking I am hitting the +/- at the same time as I am putting it into reverse and not moving yet.
Anyone have this happen?
Jim
Rustycowl69
2001 ram 3500
V10
Don't know much about 5, 6,or 8 speeds, admittedly. Is 4th gear in 6 speed a converter lockup gear?
Kap1
Ex Ram 1500 2013 owner
2022 Tundra
3.5 vvti
Haven't happened to me. I have plus minus buttons too...
See if you can find a pattern to make it happen consistently and take it dealer to fix
Good luck
