Got it thank you.This will allow you to figure it out.![]()
DIY...How To Easily Find Out Which Terminal Is Positive Or Negative On A Speaker.
DIY... Here is a quick and easy way to find out which terminal is the positive or negative on a speaker without needing to buy any expensive tools.#speaker #...m.youtube.com
Ok thanks will will this video a try and your suggestions .. For a bass knob im i better getting the lc2i knob or my alpine amp knob?This is the easiest one to follow Ive seen to set up the lc2i. I'd do it with the amp around the middle gain and once set I'd crank it right up and tune the gain on the amp to where it starts clipping with the bass eq all the way up as well. If your subs are rated to the max amp output or better. I Usually over amplify. In that case you crank all the way up with something heavy bass or a sub test track and go up until I think the subs are at the limit and dial it back a touch. Over amplifying means the amp doesn't work as hard and the sound stays clearer, but use caution as setting it too aggressively means melted voice coils.![]()
LC2i Active Line Out Converter Discussion and Review
I discuss the LC2i Active Line Out Converter, when it's necessary, go over its features, discuss how to configure it, and give you my thoughts on the final p...m.youtube.com
That I don't know. I think they both do roughly the same thing. Myself I'd lean towards the.alpine knob. My thinking being once I had the lc2 set up I'd want to leave it alone and just reset the amp gain with the knob turned all the way up and call it a day. I'd also skip the knob at first and see how going up and down with the eq on the radio worked first.Ok thanks will will this video a try and your suggestions .. For a bass knob im i better getting the lc2i knob or my alpine amp knob?
