Sub boxes without removing Fold Flat Floor?
BassDaggett
Twin Lake, MI
EcoDiesel
I want to add some base to my mildly upgraded 6 speaker system (8.4 w/Kicker 3.5", 6.5", 6" x 9"). I'd really like to add a 5 channel amp and single 8" or 10" sealed box that would add a crisp, tight bass (don't need the windows vibrating or my neighbors knowing I'm on my home), everything I've seen (other than a Kicker Hideaway, Memphis Nanoboxx, etc.) requires removal of the Fold Flat Floor. Is there anything out there that wouldn't require removing the Fold Flat Floor? I know that it might rattle with the seat down, but more often than not I would just leave the seat (and FFF) up.
thx
djd
quietpeen
2021 TRX
Hellcat
right now I'm pretty sure the only box (unless you custom make one) that allows you to keep fold flat floors is the oem alpine enclosure. If you don't have the center console you could remove the jump seat and build a box to go in it's place.
Witch
Hemi 5.7 liter
B
BassDaggett
Twin Lake, MI
EcoDiesel
I found a picture of a dual unit from "BassForms" that looked like it might allow it, however I couldn't get their website to load. Otherwise everything looks to tall. Ughh... would really rather do a box v underseat.
quietpeen
2021 TRX
Hellcat
I just went on their site and it says you have to remove them.
Witch
Hemi 5.7 liter
I am exploring a line converter and aftermarket amp to push the sub I added to the factory box ?
Not sure if that is a sound plan or not
quietpeen
2021 TRX
Hellcat
check out net audio, they make an inline harness that allows the addition of Line ouput converters with out having to cut or tap into any wires. A little pricey but worth it in my mind.
Witch
Hemi 5.7 liter
Thank you , a harness would be awesome :)
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
You are going to need to go with the custom box route. Reach out to Net Audio (netaudiowf.com). They have pre done forms but let you customize the box to your needs. For this instance you will need to work with them on the available depth in the box and then find a woofer that will fit that depth.
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
When I did my sub box I wanted to keep the floor but I couldnt find a sub I wanted that was shallow enough. So, I decided I could live without the driver side portion of the floor and has NetAudio create a box that only used that portion for the sub. I kept the flat floor on the passenger side.
My needs were exactly like yours. I used a JL 10w7 as it would still hit hard and sound great on the amount of air available in the smaller box. Also, make sure you use filler when you install the sub. People say it lets you get by with a smaller capacity box.
12sportmc
NC
Gonna also say NetAudio for the win lol. They do great work and the custom harness they made for my setup works flawlessly. Ditch the floor go with 2 12's [emoji23][emoji23]
BAMF
Southern Louisiana
2015 Big Horn
Fox acoustics makes a nice box too. You can keep the fff on one side or the other. That's what I plan on getting as soon as the funds are available who knows when that will be haha
Sent from my SM-N910V using Tapatalk
