the amp
subs
one piece of wire bridged at amp to subs
specs on subs
FPW-1200
12" Sub Woofer - DVC 900 Watts Max
FUSION PowerPlant extreme excursion woofers utilise double magnet structures, die cast aluminuim baskets and superior performance dual voice coils to produce huge power and massive bass. PowerPlant woofers produce more than generous bass from even the smallest enclosures.
Product Specifications
Magnet Structure: 200 Oz
Power Handling (MAX): 900 Watts
Voice Coil: 2.5" Black Alloy DVC
Impedance: 4 Ohms
Free Space Response (Fs): 28.5 Hz
Efficiency (1W/1M): 94.5dB
Frequency Response: 22Hz-1.2kHz
Mounting Diameter: 11.22" / 285mm
Mounting Depth: 5.82" / 148mm
Outside Diameter: 12.56" / 319mm
specs on amp
FP-600D
1 Channel D-Class Linkable Amplifier
CEA 2006 Rated
1 Ohm / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
Compatible with FUSION bass control remote
Bandwidth 10Hz – 250kHz
Signal to Noise >95dB
Fuse Rating 2 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz – 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 12dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz – 50Hz
Input Impedance 20KΩ
Damping Factor >200
T.H.D 0.05%
Dimensions D 57.5mm L 360mm H 220mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
250 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
400 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
550 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
14.4 Volt Power Output Specifications
325 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
550 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
700 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
Linked Power Ratings @ 14.4VDC
1150 Watts RMS Linked @ 4 Ohms
1550 Watts RMS Linked @ 2 Ohms
