Subs! Please help!
austin
4.7L Flex Fuel
So I bought a 2 sub and amp combo with a sealed box and they won't hit hard.http://a248.e.akamai.net/pix.crutchf...ohm_2ch-br.jpg
I tried to wire them just like this and it goes straight into protection mode when I turn them on so I took the bridge wire off (the green one in the diagram) it doesn't go into protection mode but they're not hitting as hard as I think they should
2 New Kicker 40CWS124 12" 1200W 4 Ohm Car Subwoofers 2000W 2 CH Amp Amp Kit | eBay
This is the subs and amp I bought.
EdmontonSS
Edmonton, AB, Canada
link to wiring doesnt work. Did you pull wiring for the LOC out of the rear speakers, or did you get up under the dash and go before the amp?
With the built-in crossover and taking a signal from the back speakers and amping an already-amped signal, you will notice they barely hit and the higher you turn your volume, the less bass you will feel. This is rectified by taking a clean 4 channel signal from all front/rear speaker outputs before the factory amp OR replacing your head unit with an aftermarket unit with a sub pre-out that you can just run RCA's to your amp.
if thats not the case, it could simply be the settings you have on your amp (high pass filter, bass boost, etc.) or check the equalizer settings on the factory deck.
Thats just off the top of my head. Need a bit more info to go further.
austin
austin
4.7L Flex Fuel
Ok well when I turn the balance on the deck all the way right or left the subs hit hard like they're supposed to and I have no clue why and I pulled loc from rear speakers but spliced it right behind radio
EdmontonSS
Well thats a new one... lol.
Maybe someone else has a better idea. Are your inputs reversed, does your amp have a built-in crossover that needs to be wired a certain way?
austin
austin
4.7L Flex Fuel
Dang well I'm using my stock radio the amp and subs are wired correctly now I'm pretty sure but I'm not sure about the line out converter I have it hooked into the left rear and right rear speakers
Bkhsvt
Chicago IL
Your out of polarity. 100% either reversed at the loc or the subs specifically. They are canceling each other out that's why when it gets louder with balance
BlkRamRt
SoCal
HEMI 5.7
use the front door speakers for the loc. also the link dosnt work
Bkhsvt
Chicago IL
Doesn't matter one bit where you grab your signal front or rear. You don't even have to get each side (left/right) you can join your 2 pos and 2 neg at the loc and connect to one speaker. The issue is with out a doubt a polarity issue
austin
austin
4.7L Flex Fuel
Yep that was it! I messed the polarity up on the loc fixed now and hits like I want it thanks
joshhhh
