Subs with factory stereo help
PCT
2019 2500 6.4
Northern California
Brandon-w
Yukon
2015 Ram 1500
I tapped into the rear speaker wires at the stock amp (non/less amplified) then ran into a pre amp and the pre amp changes everything to rca. It's handy to be able. To fine tune the levels.
PCT
PCT
2019 2500 6.4
Northern California
Can you post pics? I dont have a factory amp. With this line in converter, I need to tap into 2 audio channels, ground, and constant 12v. Do you know where a good spot to tap into those are?
Brandon-w
Yukon
2015 Ram 1500
You don't have a factory amp? What model is your truck there should be an amp hidden on the driver side under the steering wheel area. If you just need speaker feed doors would be an ok place to tap I think. I don't have pics rite now. I could send skme in a day or two.
PCT
PCT
2019 2500 6.4
Northern California
Maybe i do? i have a tradesman, with basic sound system.
PCT
PCT
2019 2500 6.4
Northern California
Sent from my LM-G820 using Tapatalk
Brandon-w
Yukon
2015 Ram 1500
That looks like it mine is a diff color.
PCT
PCT
2019 2500 6.4
Northern California
What trim do you have. Can you share some pics of the install?
Brandon-w
Yukon
2015 Ram 1500
I'm running a 2015 1500 sport.
Brandon-w
Yukon
2015 Ram 1500
I'll Take a look again here in a sec. I know green and white chaser is one side. I'll look and see what the other side is. I need to clean my truck quickly so I can get some pics of the back setup.
PCT
PCT
2019 2500 6.4
Northern California
get a pic yet?
Brandon-w
Yukon
2015 Ram 1500
get a pic yet?
Crap! Got sidetracked. It's getting dark here Now. If you want send me a pm or quote on here tomorrow so I can remember to get you pics and wiring colors. Sorry man!
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
The base sound system with 6 speakers doesn't have an amp, only the crappy "premium" sound systems are amplified.
PCT
PCT
2019 2500 6.4
Northern California
Do you know what or where i cant find the color diagram for the rear speakers?
