swap 5.2 to a v 10
S.A.G.L
calgary
Has anyone done a swap. I have a line on a v 10 that has everything with it, can it be swapped over with out much modifications, I dont have the experience to deal with a lot of changes. Any help will be greatly appreciated. thanks.
92greenlx
Best bet is to get the whole truck and just swap everything needed.
Sent from my SCH-I605 using Tapatalk 4 Beta
ATXHEMI
Round Rock Tx
If you don't have the experience I would pass. I'm sure there's a lot of fab work and wiring that will need to be done.
NavyGuy2007
Oak Harbor WA
6.7L
Like 92greenlx said, if you don't have the actual vehicle then I would pass. With any swap like that its best to have a donor. That way you have any brackets, bolts, harnesses and other little parts right there. If you want a V10 its best to find a wrecked one you can buy cheap, if its just the motor I'd pass.
Sent from my DROID RAZR using Tapatalk 4 Beta
S
S.A.G.L
calgary
ya your probably right, thanks for your opinion guys.
