Sway Bar Links - HELP!
ktm1217
White Mills, PA
5.2L 318ci Magnum
I have a 1999 Dodge Ram 1500 4x4 that is in need of a passenger side sway bar link. I plan on doing both links though just to get it out of the way. Hoever, my truck has a 5" Tuff Country suspension lift kit on it. My question is, can I buy the OEM links, or do I need aftermarket ones because of the lift kit?? Any help would be appreciated...thanks!
adamwilkes14
From what I can find online, the tuff country kit uses coil spring spacers and longer control arms to achieve the lift...I would think that the sway bar links remain stock.
txbass06
NE Texas
5.9 Magnum
If you can, take a pic of your current end links on the truck and post them up. I'll compare them to mine and check what we offer at work
K
ktm1217
White Mills, PA
5.2L 318ci Magnum
heres the pics of the links. The second pic is the drivers side, and the rest are the passenger side. Thanks again.
txbass06
NE Texas
5.9 Magnum
Those look like factory sway links to me. I'll post up a pic and some measurements of mine off a '97 so you can compare the two
txbass06
NE Texas
5.9 Magnum
Here's mine 1st one is passenger side and the other is the drivers
K
ktm1217
White Mills, PA
5.2L 318ci Magnum
Thanks for takin those pics. How come mine didnt come up as big as yours were?
The measurement is about 6 1/2" to 7" from the top of the link to the bottom. I couldnt really get a more exact measurement bc the ground was all mud and I couldnt really get under there too good lol
txbass06
NE Texas
5.9 Magnum
I just uploaded the pics from my phone to photobucket then used the img tags to post them up here. I completely forgot to measure mine but now that I look at my pics, it's about time to replace mine too lol
bootsdodgejn
Northern MD
5.9 cummins
Talk to thuren fab if u plan on getting stock or lifted size links. They did my links for my truck. And I have a leveling kit
Granted its not helping on figuring what u need but it is something
Sent using my Froyo Fascinate
K
ktm1217
White Mills, PA
5.2L 318ci Magnum
lol they look like theyve seen better days.. Your links do look the same as mine, so I think I'll be able to buy the stock ones for it. Thanks so much for takin those pics for me, that helped alot.
txbass06
NE Texas
5.9 Magnum
No problem man. Mine are probably the ones Dodge put on there back in '97 lol
