Switchbacks
DC Tradesman
Washington
Has anyone had success using switchbacks in the front turn lamp. If so , what kind did you use.
I am wanting a set that’s plug & Play.
Thanks
MAJ_Charlie
VA and NC
Here's what I've been using without issue.
[Anti-Fog] 2009-2018 Dodge Ram 1500 2500 3500 Black LED DRL Projector Headlights | eBay
These have been the LED headlight bulbs I have found provide the appropriate lighting for the projector lenses.
Amazon.com: TIANFUYAO H7 LED Headlight Bulbs - 100W 12000LM 6000K Xenon White - High/Low Beam,Fog Light Bulb Conversion Kit - IP67,CSP Chips,360 Degree: Automotive
As far as the brights...these work fine with the reflector lenses of these particular headlights.
Amazon.com: SOCAL-LED LIGHTING H1 Fanless LED Conversion Kit 60W 6400LM 6000K Xenon White Car Headlight Bulbs: Automotive
Doesn't require external CANBUS drivers and I was able to program my BCM for HID/LED headlights so no flicker.
Hope this helps.
DC Tradesman
DC Tradesman
Washington
Thank you for the input very much appreciated.
I’m going to look into these.
Best regards
Raadz
