Switchbacks
I went to install my switchbacks I got from superbrightleds.com today and had this issue. Put lights in with the resistor and the blinker worked fine but colundnt get the running lights to work. Is there supposed to be one in-line on the running lights too? It's a 2013 1500 with quad headlights. Try'd it with both lights as well.
BlownGP
Houston/Baton Rouge
You flip the leds around in the socket?
You only need to tap the ground and power wire
