The QSUD is the only one in that lineup that I would trust in a Hemi!
They will all work in the HEMI... The problem is the four-banger-sized oil filter. Granted, a thick 5w-30 / thin 0W-40 makes the HEMI run and sound better.
Unless you are still having Hemi tick problems(with the Redline) I wouldn’t bother with the Lubegard I don’t think you really need it. I only added it to lesser oils that you knew had little or no Moly. The 10oz bottle worked fine for me when I used it in RGT and QSUD no tick.
I wouldn't mix them, no reason to.
You don't need, and shouldn't, add Lubegard Bio Tech to Red Line Oil.
This is ms6395, I wouldn't say it was a joke for consumer, but yeah I'd be chapped if I was an oil manu, lol.
This was the main hooray... from link
Oil must pass Chrysler Las Vegas fleet test. The test is run in Chrysler vehicles for 100,000 miles in taxicabs in Las Vegas over two summers and one winter. Chrysler material engineering can supply more detail. Fleet plan must be approved by Chrysler’s Material Engineering before testing begins.
Well, Chrysler dumped m1 after their bankruptcy in 09 and opted to partner with Shell, so I imagine m1 was probably chapped about that. I wonder how much they owed m1, lol. Regardless, m1 was always a good choice for the hemi and it is the second most oil used in them, and I would wager decent money there was never a warranty denial for someone using mobil 1.
That was due to Fiat buying them.
OK like 10w30 /10w40 /15w40
It's a Custom delux 1966
The choke button is there at least
What about 15w50 mobil 1?Yes, but I am not there. thanks for that oil weight.
MOPAR claims it does not have an additive they want.
I'm guessing this isn't a power house of an engine if the seller didn't mention it, but hey anything can happen And Maybe it's just me, but higher warm number on oil doesn't that correlate with high rpm? Maybe just something kook up in my headWhat about 15w50 mobil 1?
Just got a partial can of this from a friend. Good stuff but i see its been discontinued for like 20 years lol
hey @HEMIMANN for once up weather aint ******. Sittin here at 11:06 and its 86 degrees
Short runs yes but long runs need heavier because the heat thins out oil.It depends. Generally speaking, if you want to rev the snot out of a motor you need a lower viscosity oil.
Short runs, yes, but long runs need heavier because the heat thins out oil.
