Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
knightjp
Dubai, United Arab Emirates
I've been running Amsoil SS 5w20 for several years now with either their filter or (when they're out) the Fram XG10060 synthetic filter.
Slick, smooth and quiet, I've used Amsoil for many years in many engines and never had problems.
Its not really the top oil on the forum.. I see the poll says Mobil 1 is.
However it is a great choice, if you want a good oil for your engine.
Even the engine masters on Motortrend use Amsoil for their hotrod engines and assembled stuff. Also in every oil comparison on youtube, Amsoil always comes out on top or at least is the runner up to PUP.
If I ever face another Redline 5W30 shortage, I will certainly be going Amsoil 5W30. That's what I've decided.
Rod Knock
NC, USA
AMSOIL 5W-30 is not even close in HTHS and HTFS viscosity to RedLine 5W-30. For your climate conditions (120+ Fahrenheit ambient temps), you need to run something with an HTHS north of 3.5. Of course, it's your engine, you put whatever you want in it.
What about Penzoil Ultra Platinum? Is it a good oil?
It's engine oil made by the biggest oil company on planet Earth, so of course, it's good. That being said, it won't protect any better or worse than any other lubricant in its class. If you like Shell/Pennzoil products and you do any real work with your truck, like towing, then look at the Pennzoil Euro line of lubes for better protection or PUP 0W-40 at the very least, as 5W-20 fuel economy oils aren't that great for a hardworking engine.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Amsoil is a top oil. The Hemi engine is an aberration, having a design flaw the requires bandaid oils to make it durable. This is where Red Line comes in. Otherwise, it is designed and intended for race engines.
If not for the Hemi design flaw, I would be using PUP or Amsoil, fyi.
Rod Knock
NC, USA
No, it's not.
A parts issue that's the supplier's fault is not a design flaw. The lifter is pressure lubes and gets plenty of oil via the pushrods and lifter bores when MDS is enabled. The HEMI is not a lawnmower and Uncle Tony needs to learn a thing or two about modern HEMI engines.
I never dared to call Red Line an oil intended for race engines. Once or twice I said that it's better suited for track use, and when I did that, @Burla literally cursed me out. He went from being my friend to bullying me in a split second, over frickin motor oil. Some things you just don't forget. Red Line has their own line of racing oils, but the High-Performance oils are for street use.
The Red Line High-Performance can actually be used for up to 18,000 miles or changed once a year, whichever comes first. That's per Red Line's own recommendation. Should you go that long in that kind of heat (120F+)? Absolutely not, however, Red Line makes good oil. Use it with confidence. AMSOIL makes good oil as well, however, in Dubai thicker AMSOIL with better HTHS than 5W-30 is needed.
Once again, the HEMI doesn't have a design flaw, it's a parts issue. That being said, if you work that engine, better to use higher visc oil with proper HTHS of 3.5 or higher. Red Line is an excellent choice, one of the few lubricants left at a reasonable price with a decent amount of POE in it and plenty of "old-school" additives.
Burla
2010 Hemi Reg Cab 4x4
We had an updated poll because the original one didnt have popular choices. The interesting thing is amsoil is number 3 and redline is number 4, redline certainly isnt 4th on any forums list except here. Like Hemimann said, it is an aberration. However, it is also a situation where you get what you pay for, there is non better, just not necessary in most stuff.
Mobil 1 or Mobil 1 Advanced
Votes: 310 29.8%
Pennzoil​
Votes: 319 30.6%
MontanaHandyman
Montana
Votes: 310 29.8%
Pennzoil​
Votes: 319 30.6%
I wonder if oils like Mobil and Pennzoil aren't so popular primarily cuz of marketing, price, and availability...
Burla
Marketing for sure, they aren't the cheapest and most places have many oil choices. As for Pennzoil, they even overcome a availability shortage, as they seam to not have good distribution, but yet is the most popular on the board. But, guys do follow many specs, and for a long time mobil and many oils didnt spec their oil for hemi's, so guys got pennzoil where they could. I don't remember seeing 0w40 pennzoil anywhere on the shelf, and yet it was the only hemi specific oil and widely popular. My guess guys are just using amazon, probably the only place to get it?
HEMIMANN
Minneapolis, MN
6.4L HEMI
Shell's game was always over the road trucking. Mobil was offroad equipment and industrial factories, along with retail.
When they try to grow by entering each other's markets, they don't know what they're doing.
I'll give Shell credit for launching a huge GTL marketing campaign when they bought Pennzoil and Quaker State brands. They whacked Mobil pretty good. But by that time, Mobil wasn't Mobil anymore - they are Exxon. Mobil is just a profit raking brand to Exxon.
Rod Knock
NC, USA
As opposed to what, a charity?
The lubes you mentioned are made by the same corporations who make your fuel, who follow EPA and manufacturer guidance on fuel efficiency, who are concerned with the longevity of your vehicle and wear control for your engine. In their view, it shouldn't break too soon, but God forbid it lasts too long. You get the picture.
Big money is spent on marketing at face value and guerilla-style, a la stupid YouTube reviews, people who sneak onto forums to manipulate public opinion, a gazillion websites (landing pages) with "top oils," and so on. The big oil companies will push their products, no matter what.
The underdogs, the small lube blenders like AMSOIL or Red Line (although they're part of Philips 66 Spectrum now), are the big guys' clients. Red Line Oil, HPL, Joe Gibbs Driven, and Royal Purple are the last few ones who make lubes that are more or less formulated with higher amounts of anti-wear additives, along with more detergents and dispersants, and better base oils. AMSOIL isn't even trying to stand out with their motor oil offerings anymore, as they are now compliant to a tee.
The only way to get ahead in wear control is to over-spec the oil you use in your engine. You do that, and you're golden.
Burla
Woke peanut butter? A huge staple of my diet is skippy, but wth is this? Isnt peanut butter already plant protein? Regular Skippy is 7 grams protein 16 grams fat, it is imo the perfect food if they would but take the sugar out which is not really significant. The woke skippy has the same sugar 10 grams protein everything else is the same. The difference? 3 grams Pea protein, I would bet good money that no human ever said ya know all this peanut butter needs is some peas to make it better.
HEMIMANN
Minneapolis, MN
6.4L HEMI
I don't know if these guys are legit. Their ads starting appearing in my online feeds a couple of months ago. Hadn't heard of them before.
I checked them out when I bought oil for spring a couple weeks ago, and their website said they were sold out with no estimate if or when they would restock. All of a sudden, they're advertising again.
$9.59 per quart (in gallon jugs) seems like a loss-leader sale price. Or maybe shipping is extra exorbitant. I didn't check it out in depth, you all might want to if you're buying soon. I just bought for $12.30 per quart, retail usually is $12.95 per quart. I don't "warehouse", so I don't care that much.
Rod Knock
NC, USA
@HEMIMANN I ordered two cases of Red Line 5W-30 from them last week. They put each case of Red Line in a separate box and shipped them via FedEx from PA to NC. It took two days from when I placed my order to the time the packages were delivered to my house. They ship from multiple warehouses. Your order will ship from the closest one depending on where you are located.
As soon as I get my valve cover leak on the passenger side fixed *again* (duh!!!), I am giving RedLine another shot. To add insult to injury, FedEx lost my new valve cover kit (new cover, gasket, bolts with grommets) and my new air intake filter box from the 3.0 EcoDiesel. I almost want to pull the trigger and get an S&B CAI. @HEMIMANN, how do you like yours? Did you get the reusable cotton filter or the regular one?
Pricing and service at EliteRaceFab are reasonable, and I talked to them on FB via FB Messaging. I also notified Dave @ Red Line Oil to add them to their list. They seem like good people.
retired
montana
Amazon, walmart online or local napa sometimes has it not always, local dealership always does, and my local oil distributer https://aidistributors.com all have it here. a&I of course only sells in 6 qt cases which is not big deal and is usually priced slightly more than amazon but a dollar or two a case. I found if you add it to your cart on Amazon and don’t buy it for a couple weeks and you might score a deal. I just scored a deal on some.
Burla
not bad at all.. If they ship free, as cheap as it gets the last decade plus. That is on sale though - 20%, and the 0w30 is still 9.99 a qrt, and is still the old 0w30 as they don't have the new ones out yet according to dave.
Elite Race Fab offers free ground shipping & handling to our retail customers within the lower 48 contiguous United States on most orders totaling $99.99 and higher! Orders under $99.99 will be subject to a nominal $5 Flat shipping charge. Some exceptions and/or exclusions apply,
Burla
thanks man, I see the gallons on sale as well, I think I will pick some up 38 bucks, wow, 3 gallons ship free.
MontanaHandyman
Montana
Just ordered 3 gallons, free shipping. Thanks for the tip!
OasisNinjaBat
