OK guys, I have something interesting I'd like to discus! This is in reference to the Transfer Case fluid in the Toyota 4runner, there is a lot of discussion on the Toyota recommended fluid that is a 75w. Some say it is a GL-4 and some say it is a GL-5; most of us are running a 75w90 GL-5. Dave at redline said that Toyota is using a GL-4 since 2010. I found a VOA of the Toyota 75w online, and I provided the VOA on the Amsoil 75w140; I have never seen such an interesting additive package on a gear/transfer oil like the Toyota fluid, its loaded. I also reached out to Amsoil tech line and they were pathetic, no help at all. The Toyota fluid looks to be a GL-5 with 2298ppm Phosphorus but I've gotten conflicting information. The Toyota owners manual has "NO" GL-? rating for the transfer case fluid!
My 4Runner is closing in on 60k and I'm planning to service both diffs and the transfer case, Front and rear diffs will get Redline 75w90 GL-5 but I'm thinking of switching the transfer case fluid from a 75w90 back to the Toyota 75w. Wanted to get your opinions.
The fluid you want for that transfer case is Red Line MT-LV. Ravenol also makes a 75W fluid for that transfer case, but the Red Line is easy to get from Elite Race Fab, Amazon, etc.
DO NOT USE GL5 GEAR OIL IN THE TRANSFER CASE!!! - I can't stress this enough.
You won't be able to identify by the additive package if it's a GL4 or GL5 fluid. Don't try to play chemist with a $30 VOA, you will loose. People in the business call that an Elemental Analasys for good reason. Those elemebts you see on there can be part of a friction modifying compound or anti-wear package. 99% of the people have no clue what Esters look or smell like, their toxicity level, what color raw additive packages are, how dense they are, or why Group III base oils are better than PAO for most use cases. If you're not a formulator or chemist, don't play Russian Roulete with your vehicle.
The transfer case fluid in your Toyota is a Type F automatic transmission fluid with a more robust additive package but with a Low Viscosity. You could also use Mobil Fluid LT, but it will be a hair thicker.
Red Line 75W-90NS is a GL4 type gear oil, but I wouldn't use that in a transfer case as it lacks the correct additive package.
Just use Red Line MT-LV if you want something safe and reliable. Ask David Granquest at Red Line, he will confirm.
AMSOIL is mostly a marketing company that makes some weird and stupid recomendations. They don't have anything in their lineup that would work in your transfer case.
I hope this bit of info helps. Good luck!
