Tailgate LED Light Bars...do the mess with towing package?
RocketFoot
Southwestern PA
I am thinking about getting an OPT7 Triple Redline LED bar but I'm not sure if it will mess with my towing package and dash alerts? Being that it is plugged into the trailer harness, I would think it would assume I was towing a trailer? Also, any interference with back up cam?
AFMoulton
Nuevo Mexico
CURT 55384 Replacement Vehicle-Side Custom USCAR 4-Pin Trailer Wiring Harness https://www.amazon.com/dp/B0009FJ38Q/ref=cm_sw_r_cp_api_i_VcTWDbRDWGEC6
Get one of these. Then you won’t have any issues or dash lights. I have one on my 2500 and have pulled my camper with it installed and had zero issues
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Arsenal 18x9 +12mm
Cooper St MAXX LT295/70R18
66RFE/68RFE Thermo Bypass Valve Install
2016 Durango 5.7 AWD 3.07 Redline 5W-30 RP 10-48
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Outbreak
Cummins 6.7
But they do mess with your spare tire access hole. The reason I haven't gotten one.
There is a post on here somewhere where a guy used heavy duty magnets to hold the light bar on. That way if he needed to get to his spare, he could just move it.
I have a different type of light bar that was thin enough to put above the access hole.
RocketFoot
RocketFoot
Southwestern PA
So no dash warnings...will it also not show any trailers hooked up while the light is plugged in? I have the upgraded cluster that tracks trailer hours and all that...Opt7 offers a trailer package module but I am not sure if I need that or not.
AFMoulton
Nuevo Mexico
Nope, it won’t. The way you get the trailer hooked up is from the brake power being activated. Which is a 7 way plug. The light bar uses the 4 way plug.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Curt 56584 works with the 4th Gen LED sport taillights and has a 5th pin so you don’t have to splice the reverse taillights for backup(white).
Just added a male snap to my Tailgate strip wiring and plugged it in.
The strip can be removed easily for any emergency access so that is a poor excuse. Whether it’s screwed on or 3M taped, every truck owner should have something to pry it off with.
I’d be more worried about getting the seized and corroded wing-nut off the spare wheel stud.
OC455
Central NY
Does anyone know if there is a CURT adapter that includes the backup light circuit?
Asking this because considering the bar with the backup lights.
RodeoGeorge
Edit: I think I found it.
https://www.curtmfg.com/part/56584
Yes, all you would have to do is hook up the white wire from the LED light bar into the 5 plug spot for reverse.
OC455
Central NY
Good info! Thanks guys...I think I will give it a try!
I have the OPT7 triple on my 2018. I had to get the backup camera module....I used the Curt T-harness and tapped into the wire in the middle wire of the 7 pin on the T-harness for the reverse lights.
Chino Valley, AZ USA
2019 Classic Crew Cab
What was it doing before you got the module?
RodeoGeorge
OC455
Central NY
RodeoGeorge
It was recommended to have it. I just plugged it in line with the 4 pin plug. Didn't try it without it.
Kalill Nieto
Fort Lauderdale
You must have separate turn signal. I take it from the bcm under the dash driver side. And the reverse from the light.
Sent from my SM-J737T1 using Tapatalk
turkeybird56
Central Texas
^^^^^^^^^^^^^^ Did U splice it in or make some type of a clip to go onto the reverse post from the curt setup???
OC455
Central NY
I did not use the 5 wire type, I used the four wire and just tapped off the center wire of the 7 pin plug.
I you use the the 5 pin, just use a bullet style connector to hook the white wire to the reverse on the five pin plug part.
turkeybird56
Central Texas
ok
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
The best is PUTCO BLADE tailgate light bar and they also have a y-connection harness that plugs from behind the bumper to the towing hitch light connection point. No splicing of wires and plug and play. The light bar is very bright and comes with 3 year warranty cant beat it.
RocketFoot
RocketFoot
Southwestern PA
So, I could get this T-Harness https://www.curtmfg.com/part/56584 and just hook the 5th pin to the white wire and NOT have to tap into my truck's tail light wiring? That seems like a better way to install on of these light bars??
That is correct. With the vehicle CANbus monitoring of the taillights, you really don't want to tap into the wiring for them. All of the outputs/wiring for the 7 pin trailer plug are fused relay outputs direct from the battery.
To simplify the install, buy a 5 flat trailer pigtail. Then pre-wire the light bar and you just ha e to plug it in.
Just an FYI: A four flat and five flat trailer plug are interchangeable for those that have light bars without reverse.
