Test Run
truckin151
2013 sport
It was such a nice day out, I ended up going for a quick test run / Cruise to give the newest tune revision a good run to make sure it worked fine before work tomorrow. Its not that bad, forgot to go through to reset the trans PT and WOT shift points though (they are stock now...ugh I hate stock shifts), so its not as quick as it usually is specially with the WOT shift points set so low. I normally have them go up to 6200 1-2 & 2-3. Need a better camera mount too.
Anyways enjoy.
[yt]akv1z5iRbrg[/yt]
T
truckin151
2013 sport
Yeah that popped up right after I loaded the tune. Dont even know which light it is yet havent looked, do that after dinner
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Good vid. What stall are you running your rpms jump before it grabs or moves it looks like. And what Cd is that.. I require that in my truck stat.
T
truckin151
2013 sport
2800 stall. and the CD is Trivium: Shogun, its a sweet album.
OklaHemi
new age hemi
nice video man
T
truckin151
2013 sport
Thanks guys, i'll do another one here in a few days after I get the trans setup. Also will have to grab a few when we hit the track end of the month feb.
Ares
Az
2003 / 2012 / 2004
4.7L / 5.7 / 8.3L
Sounds nice!
T
truckin151
2013 sport
Yeah just needs to be quicker. I hate babying it off the line hopefully a new set of caltracs will help that out quite a bit.
T
truckin151
2013 sport
It sits between 12.5 and 11.5, I need to get that part of the tune worked out still but I want to set it up and do a few runs at the track to get the WOT logs, there really is no areas around here thatr I can go much more above 80 without passing a cop on the side of the road.
