- Jan 17, 2016
- 23,853
- 54,912
- 14 Sport
- 5.7
DCT Clutch Simulator – Clutch Kicks Back with the ZF 8HP
Game Changer Alert: The DCT Clutch Simulator That’ll Make Your 8HP Feel Proper Manual Right, so you’ve gone down the 8HP rabbit hole like the rest of us, yeah? Got yourself sorted with …
tracktuned.uk
LawTracktunedAugust 27, 2025
Right, so you’ve gone down the 8HP rabbit hole like the rest of us, yeah? Got yourself sorted with a Turbolamik controller because you want that proper drift setup with clutch-by-wire goodness. But here’s the thing, having a button for your clutch or some dodgy electronic throttle pedal just doesn’t cut it when you’re trying to nail that perfect clutch kick or drop the clutch for a proper handbrake entry.Well, the lads over at DCT Shifter have just dropped something that’s going to make your day, the DCT Clutch Simulator. And ****** hell, it’s about time someone sorted this properly!
What’s All The Fuss About Then?
Look, I’ll be straight with you, if you’re running an 8HP with a Turbolamik controller and you’re serious about drifting, this little beauty is going to transform how your car feels. The DCT Clutch Simulator is designed to replicate the feel of a “real” clutch pedal, complete with an optional built-in 5v analog CPS (clutch position sensor) for straightforward installation.
The genius bit? It’s designed to work perfectly with the Turbolamik controller for 8HP transmissions. If you’re running the Turbolamik setup like I mentioned in my 8HP post, this thing is going to slot in beautifully.
Why Your Drifting Game Needs This
Here’s where it gets proper exciting for all you drift nutters out there. You know how I banged on about the Turbolamik being brilliant for drift applications because of the clutch-by-wire feature? Well, this clutch simulator is what makes that feature actually usable in anger.Picture this: you’re coming into a corner, you need to clutch kick to get the rear end sliding, and instead of fumbling around for a button or trying to modulate some weird electronic setup, you’ve got a proper clutch pedal that feels like the real deal. Clutch by Wire is extremely fun for burnouts, clutch kicks, or just because. and now you can do it with proper pedal feel.
The ability to drop the clutch for handbrake entries is going to be a game changer. No more guessing games, no more “is it engaged or not?” moments. You’ll know exactly what’s happening because it feels like a proper manual setup.
Built Like a Brick *********
The unit features a robust, compact design crafted from high-quality anodized aluminum for maximum durability and protection. Made in Sweden. And you know what? That shows. Looking at the specs and build quality, these aren’t messing about.The Swedish engineering really comes through in the details. It’s compact enough to fit most setups, but built tough enough to handle proper abuse. Because let’s face it, if you’re drifting regularly, your clutch pedal is going to get a right hammering.
Installation Options That Actually Make Sense
Here’s where DCT Shifter have been clever, they’ve given you two mounting options because they know not every build is the same:Firewall/Pedal Mounting: Comes with everything you need including an M8 rod with clevis link and a mounting plate that’ll fit most firewalls (62-53mm center-to-center). Perfect if you want that OEM integrated feel.
Remote Mounting: Uses a 3/8-24 UNF fitting so it connects as a slave cylinder after your main clutch master. Comes with stainless mounting bracket and even has a little M3 screw for bleeding. Proper sorted.
One thing to note – with the remote setup, you might need a helper spring to get the pedal return feeling spot on. They’re honest about it too, which I respect. Some setups work great without one, but it seems to depend on your pedal’s geometry and cylinder size. They’re working on a fix, but for now, chucking a helper spring on is the easy solution.
The Technical Bits (Because I Know You Want Them)
Let’s talk specs because this is where you can see they’ve done their homework:- Sensor Power: 5v DC (perfect for modern ECUs)
- Sensor Output: 0.5-4.5v (proper range for accurate readings)
- Sensor Range: 0-10 bar (more than enough for any application)
- Material: Aluminum throughout
- Weight: 0.8kg (not going to upset your weight distribution)
Setup Notes That’ll Save You Headaches
Here’s a proper important bit that DCT Shifter mention in their notes: When you calibrate your simulator to your gearbox controller, leave some room from when the clutch pedal is not pressed. Heat from the engine bay causes slight pressure changes (voltage rise about 0.1v at 80 celsius). So if you read ~0.5v when 0% pressed, set 0% to at least 0.8-1.0v.That’s the kind of real world advice that comes from actually testing this stuff properly, not just designing it in a computer and hoping for the best.
