The gremlin led rear lights and tow lights not working
Miloman1000
Toronto
6.7 hemi
Hi
I have a 2017 5.7 1500 I ll be as descriptive as I can
The rear right passenger tail light has three bulbs out when flashing pressing brakes and hazard it the top 3 bulbs in the left from top down I ll attach a pic
Also the yellow turn on the mirror is rapidly flashing when the turn signal is on but not when the hazards are on
I also have no turn or brake lights when connected to a 4 pin for a trailer
I’ve checked and replaced all the fuses re the trailer abs nothing
Can I open it up to replace any led bulbs?
And would this issue be causing the trailer issue also the wiring harness is factory for the trailer abs. Ohh 4 pin and 7 pin have the same result of nothing
All the relays seem to be working abs clicking on and off so I’m pretty sure it isn’t a relay my 3rd brake light was burnt but I solved that
Hope this is descriptive enough and someone can point me to the solution
Have a hunting trip planned in a few and need to sort this out
Much thanks
M
Miloman1000
Toronto
6.7 hemi
On a note when I hit my lock button on the fob those same lights mentioned above work perfectly fine
theblackduck87
Clermont, Florida
6.4L SRT8 HEMI
I would say that maybe your trailer harness wiring might be causing your issue. As far as the rapid flashing goes...Normaly the CANBUS is looking for a particular resistance from that circuit in order to flash correctly. Your hazards should be on a seperate relay from your regular blinkers.
Check your taillights and see if the 3 that are not working are incads or leds. If they are incads and are burned out that may be your issue with the quick flashing
M
Miloman1000
Toronto
6.7 hemi
I called the dealer on my vin and was given this part 68093080ac was told I need to replace the entire assembly I did check the trailer and had resistance I did see the 20amp fuse was burned so I replaced it, while at it I relaxed the 30 amp also as it did give me an issue a while back
Checked the harness and didn’t see power to two of the connectors I’m hoping the light being burned out sorts it out ordered it aftermarket for 289 dealer for oem was 500
Pull the plug out of the back of the 4/7 pin jack on the bumper, probably a corroded connection. Also double check these fuses:
F53 ATR 20 amp Left Trailer lights
F81 ATR 20 amp Right Trailer lights
F29 FMM 20 amp Trailer Park lights
There is no separate relay for the hazards nor is there a blinker relay, the lights are driven from the BCM.
M
Miloman1000
Toronto
6.7 hemi
I did change all the fuses the 20af81 was burned out no change
