The Lower Class Club....
OklaHemi
new age hemi
i use photobucket, its free and easy. make you a profile then upload your photos from your computer and it will provide you the
OklaHemi
new age hemi
here is the pic from your profile
im in love with it, i want 26's now. my wife is going to kill me. i guess i can tell her that 22's are 2000 and late. how does it ride? how much rubber do you have?
jhemi
wisconsin
last year it was at stock ride height and rode great, now that its lowered its a little sloppy feeling but im running stock shocks still rubs a little on drivers side when i turn but that could be from the deer that decided to t-bone me last fall still havnt fixed it yet, im running 305-30-26 so theres a couple inches of rubber between rim and road id like to go lower but dont want to mess up the 4wd
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Looks great, need some details on the drop and of course a lot more pictures.....
jhemi
wisconsin
the drop was the mcgaughys 2/4.5 front spindles and rear was flip kit with shackles front was a little higher so i lossened torsion keys a little i didnt modify the exhaust yet so it catches the leafs when i jack the truck up i took a few more pics but sun is out takin bike out for lil bit
jhemi
wisconsin
i put more pics in my profile il figure out photo bucket tonight so i can post them on the board
jhemi
wisconsin
Trup, your post a while back on how to modify the 2wd spindles for th 4wd trucks is how i found this site, worked good, now what can i do to make the ride quality better, she feels more tipsy in the curves and i hit the bump stops when bike is in back and hit small bumps
jhemi
wisconsin
and thanks for getting my pics on the board for me oklahemi and shadow11, and the compliments, now i just need to find roll pan that i can have the hidahitch
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Haha I'm glad I could help! That's the exact same problem I had after the drop! Hellwig Sway bar definately stiffened up the back end a ton, and the helper bags helped with the sway and keeps it off the bump stops. That, coupled with some new shocks, if you don't have any yet, will give you the perfect ride/performance handling! I also changed the rubber bushings with polyeurothane bushings, but I didn't really notice any difference from them. Good luck, and lemme know if I can help!
OklaHemi
new age hemi
sweet pics. my pan has the cut out for the hitch, its steel and has the raised licence plate which i prefer over a completely smooth one like a sir michaels. roll pand are neccessary on a lowered truck.
i wasnt 26's now too.
donaldjp
Brooklet/Savannah, GA
Donald, looking at your pictures I would guess you are in the upper holes on your shackles. If you go to the bottom holes it will raise the rear an inch to be level. Good luck..
Just went and looked at which holes i was using on my shackles and they are in the lower holes, hmmm, looks like i need to figure something different to do
Redtruck-VA
Virginia
Well that case, the easy answer is to lower the front..... believe me it never ends....
Trupiano
Registered User
6.7L CTD
If the McGaughy's shackles that came with the 2/4.5 drop kit don't give enough drop in the back, you can put the OEM stock shackles back on, but your gonna be at like 6 inches of drop in the back. That's what I did, then air'd my helper bags up till I was perfectly where I wanted to be.
Redtruck-VA
Virginia
Like I said, it never ends.... just one more inch! lol
Redtruck-VA
Virginia
I posted information about the Aeon springs I am using in the Lowered thread in the 3G section.
OklaHemi
new age hemi
sweet thanks greg
