I have a 13 mega which has the power sliding rear window. 2 weeks ago I noticed a sweatshirt I left behind the back seat was damp. I thought that I just put it back there damp from one of the times I had been plowing. I took it out and replaced it with another sweatshirt, yesterday I noticed it was damp too. I looked in the storage compartment behind the driverside rear seat and noticed it was soaked back there. So much so that a few pair of gloves I had in there needed to be wrung out and there was visible water droplets inside the compartment. So today I removed the storage compartment and insolation/carpet behind the rear seats, up against the back of the cab and started spraying the back of the truck with the house. I saw a few droplets inside and the only place it looks to be coming from as of right now is the rear sliding window. But not sure if its leaking because of the pressure of using a hose. Not sure if rain would come in the same way.
Anyone know of any water leaking issue? Or know a better way to locate the leak? Or do I just need to wait for rain?
