this freakin truck...
AJMAG
new jersey
the 5.9 developed some white smoke this morning, which we know is NOT good on a diesel. its not a **** load of smoke but its there.
is there anyway this thing isnt done and its a quick fix? first time owning a diesel so bare with me :shooter:
ramhunter9
P-Star Jeep Wrangler
Sounds like a case of needing head studs not bolts . After you fix your head dont put the bolts back in use studs . This will help in the future ,so you dont blow your head again as it seems the truck has been pushed to its limits a time or two.
Just my thought ...
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Second pulling the head and putting in studs. I dont see a tuner in your sig but I would guess you prob have one. The stock bolts can only handle a certain amount of PSI then the head will lift and pop the gasket. How does your fluids look? Nothing mixing?
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Now before do head studs... Does the smoke clear up after engine warms up a bit? Is the truck a bit difficult to start? Could be leaking injector(s).
Or it could be a grid heater issue if the temps are getting cold.
AJMAG
AJMAG
new jersey
No tuner all it has is an intake. Only smokes a little on start up. It was difficult to start one time but starts easy now.. I was thinkin either bad injectors or valve cover gasket
Mopar1973Man
New Meadows, Idaho
Watch the hard starting carefully. This is typically a sign of a leaking injector. So during cranking the CP3 can't build enough pressure to get the injecotrs to pop because of 1 or more injecotrs are leaking. Hence the white smoke after fire up. (Possible).
So it might be a good idea to either hit a Dodge dealer and a leak down test done. Or... Find a shop that can test CR injectors and pull your out and have them tested.
As for the valve cover gasket... I don't think that is going to be a cause...
ramhunter9
And the man comes threw ..^^^ i LOVE THIS GUY
that makes perfect sense
JP03
New Jersey
Cummins 5.9
My truck some times takes a little bit longer to start but it just blows black smoke more than usual when it starts
Mopar1973Man
New Meadows, Idaho
With all CR engine hard starting is something to be concerned about. I would check the basics like fuel filter, fuel pressure, air leak (loss of prime) and lift pump, etc... If all this checks out OK then I would the next step and look into the injectors by removing them and having them tested.
ramhunter9
So far I have never had a hard start .
Mopar1973Man
New Meadows, Idaho
Only time a 24V truck see hard start is when the low pressure fuel system has a air leak and looses prime. But now CR engine is a different animal vs us with 24V 2nd Gen's
JP03
New Jersey
Cummins 5.9
only happened 2 times and it has not done it in i cant remember how long
AJMAG
AJMAG
new jersey
Wasnt to bad. Just one semi clogged injector no damage done everythings fixed now. And got a smarty for it! Hauls ass now even when im only runnin it on level 4
Silvertabb3
Cummins 5.9
hope i dont get white smoke !!! always seems to come at some point though
