Throttle body spacer?
Mike42488
Long Island, NY
throttle body spacer...is it worth it, does it change alot??? questions, comments, concerns....thanks in advanced guys!
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
dont work. they fit, but they are worthless. Throttle body spacers were effective on carburetors, but they are pretty much worthless on fuel injection. In a lot of cases they actually hurt performance
Mike42488
Mike42488
Long Island, NY
interesting, i had no idea......any other cheap performace mods i can do to get a little more out of the hemi??
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
You can do a homebrew CAI. Using some PVC Pipe and some sheet metal
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I dont see a programer in your sig, a Superchips would make a world of difference for you.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Nobody mentioned a power wire yet?
Far as him making one or buying the Air Ram one? It just tricks the air sensor to dump more fuel which some claim alot of gains, alot claim nothing. His best bang for the buck would be a new or used SC and work from there.
Mike42488
Mike42488
Long Island, NY
Thank you everyone for all you info. im new to this whole forum thing and its really great, everyone is so friendly and helpful.
Thanks guys!
-mike
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Here is the power wire AirRam - Cold Air Induction System
Or many people make there own with a resistor.
The store bought Pwr Wire is sweet in as it has factory plugs and just plugs in without cutting the wires.
The home brew version uses a 4.7k ohm resistor from Radio Shack. You get a pack of 5 for couple of bucks. Anyway the "Intake Air Temperature" (IAT) sensor inputs a 0-5 volt signal among other inputs to the PCM to control injector pulse width. The resistor reduces the signal value and tells the PCM that the inlet air temp is cooler than what it actually is and the PCM adjusts the pulse to be a little richer. The IAT is located on the air box and is just a plug and twist sensor. On aftermarket CAI systems it's the sensor plugged into the air ducking. There are two wires connected to it, cut either wire and solder in the resistor or install plugs if you like. Side note when using a CAI the sensor is simply pushed into a rubber gomet, make sure it is orientated the same as when it was plugged into the air box. This as been reported as a possible problem that can cause some surging. IDK... Weedhoe has a good DIY video on another forum.
Captain McGillycutty
Maumelle, Arkansas
2011 Power Wagon
My tbs just makes a turbo sound lol. I actually think it makes it worse but I love tricking people that don't know anything about cars and I tell them my truck has a turbo.
moosehunter44
2006 5.7 throttle body spacer??
Hi don't know if im at the right place but anyway since I installed a throttle body spacer I can here the engine clicking when it changes from 4 to 8 cylinders which I couldn't hear prior to installation iassume its the cylinders changing that I hear any insite into this problem ?thanks
knucklebuster27
No relation.
Gecko
NJ
5.7L Hemi, 8.3L V10
Remove the spacer. There is no benefit to it. It's just an expensive paper weight.
gunner1374
In the 405!!!
HEMI 5.7
I kind of like my buddy's Ram "whistling" now since he installed his, lol. He claims a little better throttle response, but I just hear a whistle on acceleration. As long as he is happy with it, then more power to him I guess?
TMFMK
