throttle body spacers?
Slamminwagon
Meriden CT
3.9L
Was looking for some minor performance parts for the 3.9 non mag and quickly found nothing but I found these spacers is it worth the 25 to 30$ for it?
charonblk07
Calgary, Ab
F1-A forged 349ci
For the single plane intake that the 3.9L had it could help a bit. Which throttle body is on your year? Is it the one with the fuel injected directly into the TB?
S
Slamminwagon
Meriden CT
3.9L
I don't know much about these trucks but it's a holley with the black injectors facing down its a 88
charonblk07
Calgary, Ab
F1-A forged 349ci
87 used the Holley carb, 88-91 used a single point electronic fuel injection which is why I asked because yours could be either. If it's a carb then run the TB spacer, it'll help with the air/fuel mix before it hits the plenum.
S
Slamminwagon
Meriden CT
3.9L
Mine is the holley carb for sure cause if I take the air cleaner off it says holley on it so I should go for it
S
Slamminwagon
Meriden CT
3.9L
Never mind my friend has a 89 dakota sport with the 3.9 he confirmed that it has the fuel injected tb so is it worth it?
charonblk07
Calgary, Ab
F1-A forged 349ci
It's still injected before it enters the plenum, a throttle body spacer is a worthwhile investment.
