Commander 06
Thinking of swapping out the stock 65mm throttle body off my 4.7l wanted to see if the stock 5.7l throttle body would fit the 08 up 4.7l is a 65mm throttle body with 4 bolts. The stock 5.7l throttle body I believe is 75mm throttle body with 4 bolts anybody try this swap yet?.. thinking if it dose bolt up I would have to port the plastic intake manifold to clear the throttle body butterfly which would be fairly easy to do. Biggest question is will it bolt up?
