David1027
So I have a 2013 Dodge ram 1500. I’m getting two error codes.
The first error code is low reference voltage circuit B
And the other error code is throttle
The actual code is P2127 and P 0652
I changed out the throttlebody and hooked it up to a scanner to relearn. The throttlebody would not relearn. This leads me to believe that the old throttlebody may not have been the problem either. The low reference voltage I would have to say is got something to do with the whole problem.
I have looked for loose connectors. I have looked for damaged wires. I have not found anything. The truck will start an idle just fine, but there is no acceleration whatsoever. If anybody has any ideas on this, please fill me in or point me in the right direction.
