Ticking at certain speed?
tommyboi87
houma louisiana
5.2 Magnum
The seafoam should help with the lifter, if it is a lifter.
Sent from my SAMSUNG-SM-G925A using Tapatalk
tommyboi87
houma louisiana
5.2 Magnum
Best bet would be to have a mechanic find out where/how your oil I getting consumed like that.
05ram4x4
05ram4x4
2002 Ram 2500 4x4 Quad cab
5.9 Magnum
Well the more I hear this sound, the more I'm thinking it's rod knock, or a spun bearing, or something along those lines. I was driving along probably about 25mph, and I have it a lot of gas to see what happened. As the rpms rose, the sound was pretty loud! Definitely more of a knock than a tick.
tommyboi87
houma louisiana
5.2 Magnum
Next time you change your oil, check for any kind of particles (metal) or anything. A way I found out I had thrown a rod in my LS1 was by dropping the pan and trying to wiggle the rod caps checking for play. As for a spun bearing if it starts to sound like a hammer hitting the block, there's a good sign. Also cut that oil filter open. See if you're getting any glitter in there.
05ram4x4
05ram4x4
5.9 Magnum
I noticed today that when the motor is cold, it doesn't do it.
05ram4x4
05ram4x4
5.9 Magnum
So I Seafoamed it and it didn't make a difference, as far as the knocking sound goes. I was starting to think spark knock, but that wouldn't happen right when I start it cold would it? I hear the sound for a second when I start it. Every time. At temp, or cold.
05ram4x4
05ram4x4
5.9 Magnum
So, it definitely only does it under load. For sure. If i'm sitting parked, and rev it it does it if i hold it at above 2000 rpms. If it just quick rev it, it does it every time i let off. If I"m driving, and drop down to 2nd, it does it loud if i give it gas. So what could it be that is ONLY under load?
05ram4x4
05ram4x4
5.9 Magnum
I don't know what to think anymore. I recorded a short clip from inside the truck.
05ram4x4
05ram4x4
5.9 Magnum
I'll fix that in a little while. Sorry
05ram4x4
05ram4x4
5.9 Magnum
Should be fixed. But anywau, I realized that it DOESN'T do it under load. If I sit here in park and Rev it, it will do it. If I put it in drive and hold the brake and Rev it, it doesn't do it.
05ram4x4
05ram4x4
5.9 Magnum
So, I'm not sure what this. Yes I KNOW I shouldn't drive it. I know. But I do, so skip the lectures.
I have a tranny problem now with a late 1-2 shift. This causes my rpms to rise significantly more than usual when driving normally. The engine knock or tickets severely when it does. I just can't believe it hasn't thrown a rod yet, so I'm still wondering what it is. I am going to drop my oil pan this weekend and take a look at things.
Also, is there a gadget for the oil pan? Or is it rtv like everything else? Anything special to know about dropping the oil pan?
Sent from my SM-N910T using Tapatalk
aimcgma
