Ticking at certain speed?
05ram4x4
2002 Ram 2500 4x4 Quad cab
5.9 Magnum
I've noticed on the highway, around 75-80 mph, I hear a slight ticking from what I assume is the engine. Only seems to happen when I have my foot on the gas a little to keep it at those speeds. If I let off it stops. If I give it more gas, it stops. Or I just can't hear it anymore. I want to say I have an oil issue. I know I have an issue with oil disappearing between oil changes. Is there anything I can check, or test?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
If it were oil, it would increase with RPM. You might have spark knock going on.
05ram4x4
05ram4x4
5.9 Magnum
How should I go about fixing that or testing it? I do t want to ruin anything. I already had a head crack in me once.
MagSport
South Carolina
I would say it's an exhaust leak. Mine does the same thing and I have a plethora of holes between the cat and muffler.
05ram4x4
05ram4x4
5.9 Magnum
I don't think it's an exhaust leak, because I hear a definite exhaust leak as a separate sound.
05ram4x4
05ram4x4
5.9 Magnum
I fixed the plenum as soon as I bought the truck. Still looks like new in there.
05ram4x4
05ram4x4
5.9 Magnum
I don't remember off the top of my head. But I know I hadan issue before with plugs being the wrong temperature but I fixed that
05ram4x4
05ram4x4
5.9 Magnum
So, I had the truck sitting, all warmed up from driving all day, and i revved it to 2000 rpms, and held it there. I could hear the ticking, or knocking. And it was pretty loud. And it definitely picked up speed with rpms. So, what should I do?
05ram4x4
05ram4x4
5.9 Magnum
How would that help me?
tommyboi87
houma louisiana
5.2 Magnum
If something is sticking causing it to tick/knock it usually breaks it down. Take a little less than a quarter of the bottle and pour it in the crankcase. If anything it'll clean the bottom end.
Sent from my SAMSUNG-SM-G925A using Tapatalk
05ram4x4
05ram4x4
5.9 Magnum
I'm just worried that I have an oil issue. I know I'm losing oil somewhere, as whenever u change my oil I only seem to get 3 quarts out if the motor. I feel like it's not getting where it's supposed to at higher rpms. But I'll try that.
tommyboi87
houma louisiana
5.2 Magnum
When you did you plenum repair, did you change the plate too, or just the gasket? Also, is it at a good level right now? I mean, you are replacing the missing oil between changes right? Low oil will cause you to hear a tick too.
05ram4x4
05ram4x4
5.9 Magnum
I added another quart 6edterday at it was low. Yes, I replaced the plate too. I know the deal with the plenums, and how they really need to be fixed.
tommyboi87
houma louisiana
5.2 Magnum
Just checking. Some people just replace the gasket. Any leaks on the oil pan or dripping down the valve covers? Smell burnt oil at startup or once it's warm? Any smoke at all?
05ram4x4
05ram4x4
5.9 Magnum
No smoke whatsoever. I'll have to take a look when I have a moment for drips, but I don't ever recall seeing anything at all.
tommyboi87
houma louisiana
5.2 Magnum
I'd say you have a sticking lifter. As for the oil no smoke and no smell, then a gasket needs replacing, but if you close to two quarts low at oil change, it sounds like your burning more than you are leaking. A leak like that, you'd have drips in the driveway.
05ram4x4
05ram4x4
5.9 Magnum
Wonderful... well is there any way to confirm a sticking lifter?and what do I do about burning oil?
KAKA
